This guide contains all permissions and requirements for connecting your Instagram Insights data to Supermetrics.
If you'd like to connect your Instagram Public Data to your report, take a look at our Instagram Public Data connection guide.
To connect Instagram Insights to Supermetrics, you need to make sure both your Instagram and Facebook accounts have a specific set of permissions. We have detailed instructions on how to set up the permissions in our Instagram Insights: Permissions guide.
Your Instagram account must be:
- An Instagram Business account (sometimes called a "professional account"), or a Creator account that uses Facebook authentication and isn't restricted, age-limited, or private.
- Linked to an active Facebook Page which has been claimed.
Visit Instagram's help center to learn how to change your account type.
Your Facebook account must:
- Be a Facebook user account with Insights permissions.
- If it's using the new Pages experience, the account needs Full control access to the Facebook Page linked to the Instagram account.
Note that Story data is only available in Instagram Insights for 24 hours after a Story is created. This means that you'll need to use the "Combine new results with old" setting in Google Sheets to add this data to your reports. Learn more.
When connecting to Instagram Insights, you need to log in to Facebook and select the pages to use in your reporting when prompted.
- Select the Instagram Insights data source on the Supermetrics Hub or in the data destination.
- Log in with a new Facebook account, or click Continue as to log in with the account you're currently logged in to.
- Select the Businesses, Pages, and Instagram Accounts you want to include in your reporting.
- Review the permissions, and click Save.
- Click Got it.
- In your data destination, select the pages to include in your reporting.
You can also connect to Instagram Insights from these destinations:
- Instagram Insights report building guide
- Instagram Insights: Permissions guide
- Instagram Insights troubleshooting
- How to reauthenticate a data source in Google Sheets, Looker Studio, Excel, or Power BI
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
