Use this guide to connect your Facebook billing data to Supermetrics. This includes your lists of invoices and invoicing amounts, as well as rich metadata, campaign, and performance data for each invoice.
To connect Supermetrics to Facebook Billing Data, you need the Finance Editor access level. Learn more about Facebook Business Manager permissions.
You also need to have monthly invoicing enabled for your Facebook Business Manager account to get its invoice data. Supermetrics can't pull data on transactions that aren't part of a monthly billing cycle. Learn more about monthly invoicing.
- Click Create query.
- Under Data source, select Facebook Billing Data.
- Either log in with a new Facebook account, or click Continue with Facebook to go ahead with the account you're already logged in to.
- Click Done.
- Click OK.
- Select the accounts you want to add to your reporting.
- Navigate to Facebook Billing Data and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Facebook Billing Data requires authorization to connect to data").
- Click Done.
- Click OK.
- Select the accounts you'd like to add to your reporting.
