Follow these steps to connect your Xing Ads data to Supermetrics.
To fetch data from Xing Ads, your personal Xing account must have access to an Agency advertising account and the necessary customer data. To get access, contact the Xing admin of your agency.
- Ads: Measure the performance of your paid advertising.
- Under Data source, select Xing Ads.
- Enter a name for your login for you to identify it later.
- Enter your Xing account credentials and click Log in.
- Navigate to Xing Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Xing Ads requires authorization to connect to data").
- Click Done.
- Select a query type.
- Click Next.
