Use this guide to connect your CallRail data to Supermetrics, and start adding it to your reporting.
To connect Supermetrics to CallRail, you need:
- An API key. Follow these instructions in CallRail’s documentation to create your key.
- The Admin, Manager, or Reporting user role level for each business account. Learn more about user roles and user management.
- Returns data on calls and leads acquired through calls. Find metrics like the number of calls, answer rate, call duration, lead amount, and lead value.
- Gathers data about call insights by splitting the data by time, call source, number, or agent. This can help with resource planning and identifying the best-performing agents.
- Gathers data on a specific call and fetches direct links to recordings.
- Returns data on form submissions and leads acquired through forms. Find metrics like the number of form submissions, lead amount, and lead value.
- Gathers lead insights by splitting the data by time or by source. You can also fetch all form submission data to dig into specific answers.
For Excel users
- Under Data source, select CallRail.
- Enter your API key, and click Start.
- Choose your query type.
- Navigate to CallRail and click Try.
- Click Authorize.
- If you're connecting CallRail for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
