Follow these steps to connect Outbrain Amplify to Supermetrics, and start pulling its data into your reports.
To connect Supermetrics to Outbrain Amplify, you need API access from Outbrain.
- Contact your account manager at Outbrain to allowlist API access for your account. Alternatively, fill out this form to request API access from Outbrain.
- Once Outbrain has approved your API access, follow the steps below to complete your connection.
- Under Data source, select Outbrain Amplify.
- Enter your username and password, and click Start.
- Select the accounts you'd like to use in your reporting.
- Navigate to Outbrain Amplify and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Outbrain Amplify requires authorization to connect to data").
- Enter your Outbrain Amplify username and password, and click Start.
