Impact connection guide
Follow these steps to connect your Impact data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Impact connector, you need a copy of your Account SID and Auth Token.
Get your Account SID and Auth Token
  1. Log in to the Impact.com platform.
  2. From the bottom left, navigate to Settings.
  3. Under Technical, navigate to API.
  4. Under the API Access tab, you can find your Account SID and Auth Token.
  • Performance by Ad / Partner / Date: Get performance data aggregated on an ad, partner, and daily level.
  • Performance by Partner group: Get performance data aggregated on the partner group level. This report only returns data for Partners that are part of a Partner group.
  • Performance by Country: Get performance data aggregated on the country level.
  • Advanced action listing: List all actions and their details generated in a selected date range.
  3. Click Create new query.
  4. Under Data source, select Impact.
  5. Enter your Account SID and Auth Token.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  2. Navigate to Impact and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Impact requires authorization to connect to data").
  6. Enter your Account SID and Auth Token.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Choose to make this connection shared or private.
  9. Click Start.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Impact.
  5. Click Start.
  9. Click Start.
Power BI
  3. Click Select data source.
  4. Select the Impact data source.
  7. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Impact data source.
  8. Click Start.
Supermetrics Hub
  4. Hover over the Impact data source, and click Connect.
  7. Click Start.
