Follow these instructions to connect your Omnisend data to your Supermetrics reports.
To connect Supermetrics to Omnisend, you need:
- An ecommerce store or website connected to your Omnisend account
- An Omnisend API key. Learn how to generate this key in Omnisend's documentation.
- Under Data source, select Omnisend.
- Enter your account name and API key.
- Select the accounts you'd like to include in your reports.
- Navigate to Omnisend and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Omnisend requires authorization to connect to data").
