Follow these steps to connect your Sprout Social data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Sprout Social to Supermetrics, you need:
- An account that's been provisioned for API by the Sprout Social account owner
- An API token
- Your account's owner should follow Sprout Social's instructions to create this token.
Note that to fetch engagement data for X (Twitter), you need to approve additional permissions.
Our Sprout Social connector supports 2 query types:
- Posts performance: Measure your social media posts' user engagement.
- Tags performance: List your social media tags.
- Under Data source, select Sprout Social.
- Enter your API token.
- Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple accounts.
- Select a query type.
- Navigate to Sprout Social and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Sprout Social requires authorization to connect to data").
- Click + Create transfer.
- Select the Sprout Social data source.
- Accept the agreement.
- Click Authorize with Sprout Social.
- Click Submit.
- Click Save.
- Select the Sprout Social data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Sprout Social data source, and click Connect.
