This guide contains all permissions and requirements for connecting your Pipedrive data to Supermetrics.
You need a Pipedrive account to pull data.
- Leads: Retrieve detailed insights on your Pipedrive leads data.
- Deals: Retrieve detailed insights on your Pipedrive deals data.
When connecting to Pipedrive, you need to log in to Pipedrive and select the accounts to use when prompted.
- Select the Pipedrive data source on the Supermetrics Hub or in the data destination.
- Log in to Pipedrive. If you're already logged in to Pipedrive in the browser, Supermetrics will use those credentials automatically.
- Click Continue to app.
- In your data destination, select the account to pull data from and a query type to use.
You can also connect to Pipedrive from these destinations:
