Follow these steps to connect your Supermetrics Storage to Looker Studio.
- Go to Looker Studio.
- On the left, click Create → Data source.
- Select the BigQuery connector offered by Google.
- In My projects, select your Supermetrics Storage.
- Select your dataset.
- Select your table.
- Check the Use DATE as date range dimension checkbox.
- Click Connect.
- In the data field preview screen, click Create report.
