Connect Indeed Reviews to Supermetrics to start pulling its data into your reporting. You can fetch up to 200 of the latest reviews for any business with an Indeed page.
To connect Indeed Reviews data to Supermetrics, you need a business' Indeed Company ID. You don't need an account or login.
To find an Indeed Company ID:
- Open the business' Indeed page.
- Copy the string after /cmp/ in the URL.
- For example, a business called Example Business would have a URL ending in /cmp/example-business. Here, the Company ID is example-business.
For Excel users
- Click Create query.
- Under Data source, select Indeed Reviews.
- In the sidebar, navigate to Report configuration.
- Enter the Indeed Company ID in the Company name field.
- Navigate to Indeed Reviews and click Try.
- Click Authorize.
- If you're connecting Indeed Reviews for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Enter the Indeed Company ID in the Company ID field.
