Follow these steps to connect your Celtra data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Celtra account, you need to get your Celtra Account ID and to create an API application inside Celtra.
- Log in to Celtra, and open your dashboard.
- Go to the Reporting Center.
- Click the green + button on the right to open the report builder.
- In “Search dimensions”, enter “Account ID”.
- In “Search metrics”, select any metric from the list.
- Click Generate report.
- Copy your Account ID from the report to use later.
- Click your name in the top right of the navigation bar and select Settings.
- Select the API Apps tab.
- Click Add API App.
- Enter a name for the app, for example, “Supermetrics”.
- Click Save to create the API app.
- Copy the App ID from the list and copy it for later.
- Under Secret Key, click Show Key.
- Copy this key and store it in a secure place for later.
Query type
- Campaign performance: Measure the performance of your creatives on different platforms.
- Under Data source, select Celtra.
- Enter your Account ID, App ID, and Secret Key.
- Navigate to Celtra and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Celtra requires authorization to connect to data").
- Select the accounts to use in your report and a query type.
- Click Next.
- Click + Create transfer.
- Select the Celtra data source.
- Accept the agreement.
- Click Authorize with Celtra.
- Click Submit.
- Click Save.
- Select the Celtra data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Celtra data source, and click Connect.
