Great to have you here! Follow these steps to get started with Supermetrics for Looker Studio.
- First, connect to data sources from Looker Studio.
Take a look at our data source connection guides for the details you need to connect. - Once connected, you can start setting up your report and create your first query!
All the steps so far are also explained in the video below:
Learn more
Explore the articles on using Supermetrics in Looker Studio and the best practices for Looker Studio to deepen your knowledge with relevant topics.
To get the most out of your data sources, take a look at our report building and query setup guides.
And, to make your reports really stand out, try out the Supermetrics Charts for Looker Studio.
Video tutorials
Check out our video tutorials on the most commonly used Supermetrics for Looker Studio features.
Report templates
We have a wide range of report templates available for Looker Studio in our template gallery.
Follow this guide to populate the template with your data.
In case something doesn't go as expected in Looker Studio, take a look at our troubleshooting articles for Looker Studio.
If you're having issues with a data source, check out the reauthentication guide and articles related to the data source.
Reach out to our support team if you can't find an answer to solve your issue.
Happy reporting!
