Learn how to connect Glassdoor Reviews to Supermetrics, and start adding publicly available company review data to your reports.
You can query data from Glassdoor Reviews without logging in to Glassdoor.
To pull data on a company on Glassdoor, you'll need to copy the company's identifier — called its company ID — from its Glassdoor URL.
For example, if a company's Glassdoor Reviews URL is glassdoor.com/Reviews/Supermetrics-Reviews-E1234567, its company ID is 1234567.
Query type
- Reviews: Fetch up to 100 of the latest public reviews for a company.
- Under "Data source", select Glassdoor Reviews.
- Navigate to "Report Configuration", and enter the company ID and the language you'd like to pull reviews for.
- Navigate to Glassdoor Reviews and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Glassdoor Reviews requires authorization to connect to data").
