This guide gives instructions on how to connect Google Play Reviews with Supermetrics in Google Sheets, Data Studio, and Excel.
Google Play Reviews will return data for 400 most recent reviews for any app in the Google Play Store.
Searches are carried out with app IDs that can be extracted from the Play Store URL.
- For example, for https://play[dot]google[dot]com/store/apps/details?id=ee.example.client, the ID would be ee.example.client.
- Under Data source, select Google Play Reviews.
- Select the query type.
- Insert the Google Play ID.
- Navigate to Google Play Reviews and click Try.
- Click Authorize.
- Click Authorize.
- Click Next.
Connections
Before you can authenticate Google Play Reviews in Excel, you need to install the Supermetrics add-in.
- Click Data → Show Supermetrics
- Under Data source, select the data source.
- BigQuery
- The Supermetrics API
