Follow these steps to connect your Klaviyo data to Supermetrics.
To connect to Supermetrics, your Klaviyo account needs one of these user roles:
- Admin
- Owner
- Manager
Learn more about user management and privileges in Klaviyo's documentation.
You'll also need to generate an API key, which you'll then use to connect your data. Follow these instructions to generate your API key. Remember to keep it safe.
- Under Data source, select Klaviyo.
- Enter your API key.
- Select the accounts you'd like to use in your reporting.
- Navigate to Klaviyo and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Klaviyo requires authorization to connect to data").
