Adobe Commerce (Magento 2) connection guide
This guide contains all permissions and requirements for connecting your Adobe Commerce (Magento 2) data to Supermetrics.
Before using the Adobe Commerce (Magento 2) connector, you need to generate API credentials in your store admin page.
To get your API credentials:
  1. In the Magento admin panel, go to SystemIntegrations and select Add new integration.
  2. Enter a name for the integration, for example, "Supermetrics", and enter your password. You can ignore the other fields.
  3. Under Basic Settings on the left-hand side, select API and give the integration access to the following resources:
    • Sales > Operations > Orders > Actions > View
    • Customers > All Customers
    • Stores > Settings > All Stores
  4. Click Save.
  5. In the list of integrations, click Activate for the new integration and click Allow.
  6. Copy the generated credentials (consumer key, consumer secret, access token, access token secret).
  • Orders: Fetch order-level data and metrics from your store.
  • Order items: Fetch item-level data and metrics from orders in your store.
  • Customers: Fetch details of all customers registered in your store.
When connecting to Adobe Commerce (Magento 2), you need to provide your API credentials.
  1. Select the Adobe Commerce (Magento 2) data source on the Supermetrics Hub or in the data destination.
  3. Enter a name for your account to identify the login later in case you have multiple accounts.
  4. Enter the API credentials.
  5. Click Start.
  6. In your data destination, select the stores to include in your query and a query type to use.
You can also connect to Adobe Commerce (Magento 2) from these destinations:
