Follow this guide to connect your Semrush Analytics data to Supermetrics.
To connect Supermetrics to Semrush Analytics, you need an API account and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
Semrush Analytics supports 5 main types of queries — Domain, Keyword, URLs, Display Ads, and Backlinks — for a total of 35 different query types.
- Our connector uses the same structure as the API reports with the same names, so you can use the Semrush Analytics API documentation to explore the full range of reports and fields.
- Under Data source, select Semrush Analytics.
- Enter your Semrush Analytics email and password, and click Log in.
- Click Approve.
- Select a query type.
- Enter one or more domains, separating each one with a comma with no whitespace (,).
- Navigate to Semrush Analytics and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Semrush Analytics requires authorization to connect to data").
- Click Approve.
- Select a query type and click Next.
- Click Approve.
