Supermetrics is available as a connector in Power BI Desktop starting from Power BI Desktop version 2.128.751.0 (April 2024 update). No installation is required.
About Supermetrics custom connector in Power BI
If you're using a custom version of the Supermetrics connector that you installed manually, we recommend switching to the certified version, which supports scheduled refreshes and other native Power BI features.
The simplest way to do so is to remove Supermetrics from the Custom Connectors folder on your computer. See our instructions for switching from custom connector to the certified connector.
- To find the Supermetrics connector in Power BI, click Get data in the Home ribbon and choose More to view all connectors.
- Start typing "Supermetrics" in the search field and click the connector name to launch it.
- The first time you open the connector, you're prompted to log in to your Supermetrics account.
- To start pulling your data using Supermetrics, register a Supermetrics account by logging in to the Supermetrics Hub with your Microsoft or Google account using this link. Registering allows you to access the Supermetrics Hub platform, where you can connect to your data sources and build your initial queries for Power BI.
