Amplitude connection guide
This guide contains all permissions and requirements for connecting your Amplitude data to Supermetrics.
You need an API key and secret key in order to connect to Amplitude.
  1. Open the Amplitude web interface.
  2. Click Settings in the top right corner and select Organization settings.
  3. Click Projects in the left sidebar.
  4. Select the project you wish to connect to.
  5. Under General, click Show next to API Key and Secret Key.
  6. Copy the API Key and Secret Key to a secure location.
Region
Amplitude projects are hosted either on Standard server or EU residency server. In order to identify where your project is hosted, open the Amplitude web interface and check the URL:
  • app.amplitude.com – Your project is hosted on Standard server.
  • app.eu.amplitude.com – Your project is hosted on an EU residency server.
  • Events: Fetch all events across a specified time range, including its values and event properties.
When connecting to Amplitude, you need to provide your API key and secret key and select the region when prompted.
  1. Select the Amplitude data source on the Supermetrics Hub or in the data destination.
  2. Insert the API key and secret key.
  4. Click Start.
  5. In your data destination, select the region.
You can also connect to Amplitude from these destinations:
