Follow these steps to connect your Marketo data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Marketo data source connector, you must create Supermetrics API permission setup and a Supermetrics API user in Marketo, and set up an installed service, as well as find your client ID, client secret, and your Munchkin ID.
Go through the following steps to obtain the information required to log in to the connector.
- Log in to Marketo, and go to Admin → Security → Users & roles.
- Select Roles from the top and click New role.
- Set the following role details:
- Role name: Can be anything, such as "Supermetrics API access".
- Description: Can be left empty.
- Permissions: Select everything from the "Access API" category.
- In Marketo, go to Admin → Security → Users & roles.
- Click Invite New User from the top to set up a Supermetrics API user, and follow the creation screen.
- Set up general information in the Info view.
- Email: Can be anything, but use a valid email address.
- First name: Can be anything.
- Last name: Can be anything.
- Reason (optional): Can be anything, such as "API user for Supermetrics".
- Access expires: Never
- Click Next.
- Set up permissions in the Permissions view.
- Roles: Select the new user role that you created in the earlier step.
- Check the box next to API only user.
- Click Next.
- In the Message view, click Send.
- In Marketo, go to Admin → Integration → LaunchPoint.
- Click New → New Service from the top to set up an installed service.
- Follow the creation screen and input the information below:
- Name: Can be anything, such as "Supermetrics"
- Service: Custom
- Description: Can be anything, such as "Service used by Supermetrics to fetch data from Marketo".
- API only user: Select the API-only user that you created in the earlier step.
- Click Create.
The installed service has been created, and you can proceed to the next step to obtain the client ID and client secret for connector authentication.
- Find the installed service that you just created.
- Click View details next to the service name. A new window with a client ID and client secret will open up.
- Copy the client ID and client secret for later use — you'll need them when authenticating Marketo in Supermetrics.
- In Marketo, go to Admin → Integration → Munchkin.
- Under the Tracking code section, you should see your Munchkin ID in the "123-ABC-987" format.
- Copy the Munchkin ID for later use — you'll need it when authenticating Marketo in Supermetrics.
- Under Data source, select Marketo.
- Enter the client ID and client secret for your installed service.
- Enter the Munchkin ID of your Marketo instance.
- Add a Subscription name for your Marketo instance. This can be anything and is only used as a display name of your connection.
- Navigate to Marketo and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Marketo requires authorization to connect to data").
- Click Select data source.
- Select the Marketo data source.
- Fill in the query details.
- Hover over the Marketo data source, and click Connect.
