This guide contains all permissions and requirements for connecting your Google BigQuery data to Supermetrics.
You need a Google account with access to view and manage tables in BigQuery in Google Cloud in order to connect.
Required Google Account permissions:
- View and manage your tables, datasets and jobs in Google BigQuery
- See the email address for your Google Account
You also need to get your table ID and identify the date column in your table.
To obtain your table ID:
- Identify the BigQuery table you wish to connect to in the Google Cloud console.
In the left-hand Explorer section, click on the three dots next to the table.
Select Copy ID and save this for later.
To identify your date column:
- Select your table in the Google Cloud console and open the Schema tab.
- Copy the field name of the column you want to use for date range filtering.
Please note that your BigQuery table must have a DATE or DATETIME column in order to fetch data for specific date ranges.
- Table: Fetch data from your table in BigQuery.
When connecting to Google BigQuery, you need to be logged in to your Google account.
- Select the Google BigQuery data source on the Supermetrics Hub or in the data destination.
- Insert the table ID.
- In your data destination, fill in the value for the Date column setting.
You can also connect to Google BigQuery from these destinations:
