Follow these steps to connect your Taboola data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Your Taboola account needs at least the Account manager user role to connect to Supermetrics. Learn more about user roles in Taboola's documentation.
- Under Data source, select Taboola.
- Enter your credentials, and click Sign in.
- Select the profiles you'd like to use in your reporting.
- Navigate to Report configuration and select a query type to use in your report.
- Navigate to Taboola and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Taboola requires authorization to connect to data").
- Select the profiles and query type you'd like to use in your reporting, and click Next.
- Click + Create transfer.
- Select the Taboola data source.
- Accept the agreement.
- Click Authorize with Taboola.
- Select the profiles you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Taboola data source, and click OK.
- In the transfer setup view, select the profiles you'd like to include in your reporting.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Taboola data source, and click Connect.
