Use this guide to connect Yelp Reviews to Supermetrics, and pull up to 100 of a business' most recent reviews.
You need a business' Yelp Business ID before you can pull its review data from Yelp Reviews.
You can find any Yelp Business ID by copying the text that comes after /biz in the URL for any business' Yelp page.
For example, if you opened the Yelp page for a business called Article Example Business, its URL would end with /biz/article-example-business. Here, the business's Yelp Business ID is article-example-business.
For Excel users
- Click Create query.
- Under Data source, select Yelp Reviews.
- Enter the business' Yelp Business ID.
- Navigate to Yelp Reviews and click Try.
- Click Authorize.
- If you're connecting Yelp Reviews for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
