Shopify reconnection required - June 18, 2025
We're upgrading our Shopify data source to a newer API version (Shopify API v2024-10). This upgrade needs the user to accept additional permissions to fetch location-specific fields. To accept the new permissions, you need to reconnect the Shopify data source.
What you need to do
You need to reconnect the Shopify data source after June 18, 2025, if you use the “Location name” dimension in your reporting.
Follow the regular steps to connect to Shopify. You should see the "Update data access" request showing the new permissions. Accept those and complete the connection process. If you don't reconnect to the Shopify data source after June 18, 2025, you'll get an error message asking you to reconnect to grant the permissions.
We're here for you
If you have any questions or concerns, contact our support team.
