Use this guide to connect your Facebook Ads data to Supermetrics.
Your Facebook Ads accounts need different types of access to pull different types of data. Make sure your accounts have the right permissions before going ahead.
Your Facebook account needs:
- Employee access with the View performance option enabled, or Ad account analyst access to an ad account.
- If you're using the new Pages experience, your account needs partial access to the linked Facebook account.
For access to Lead data, your account needs:
- Lead manager or Page admin access
- Click Create query.
- Under Data source, select Facebook Ads.
- Either log in with a new Facebook account, or click Continue with Facebook to go ahead with the account you're already logged in to.
- Click Done.
- Click OK.
- Navigate to Facebook Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Facebook Ads requires authorization to connect to data").
- Click Done.
- Click OK.
