This guide contains all permissions and requirements for connecting your Google Ads Keyword Planner data to Supermetrics.
The user connecting Supermetrics to Google Ads Keyword Planner must have the standard permission in the Google Ads account from which they want to pull data.
- Keyword Performance: Get insights into how keywords might perform based on historical data.
When connecting to Google Ads Keyword Planner, you need to log in to Google when prompted.
- Select the Google Ads Keyword Planner data source on the Supermetrics Hub or in the data destination.
- Select the Google account associated with your Google Ads account where you want to fetch data from.
- Click Allow to allow the Supermetrics app to access your profile data.
- In your data destination, select the account to pull data from.
You can also connect to Google Ads Keyword Planner from these destinations:
