Follow these steps to connect your Affluent data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Affluent to Supermetrics, you need:
- An API key
- An API URL
To get your API key and API URL:
- Contact your Affluent administrator to get the API key. Remember to keep the API key safe.
- To get your API URL, replace {server} in the following URL with the name of your Affluent server: https://{server}-api.affluent.io/
- Find your Affluent server name in your Affluent URL. For example, for the Affluent URL accountname.affluent.io/, the server name is accountname.
- Don't forget to include / at the end of your API URL.
- Performance: Fetches detailed performance data for affiliate marketing campaigns.
- Under Data source, select Affluent.
- Enter your API key and API URL.
- Navigate to Affluent and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Affluent requires authorization to connect to data").
- Select a query type.
- Click Next.
- Click + Create transfer.
- Select the Affluent data source.
- Accept the agreement.
- Click Authorize with Affluent.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Affluent data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Affluent data source, and click Connect.
