Follow these steps to connect your Adtraction data to Supermetrics.
To connect Supermetrics to Adtraction, you need an Adtraction API token. These are also referred to as API keys.
To generate this token:
- Log in to Adtraction.
- Navigate to Account → Settings.
- Select API from the navigation menu.
- Copy the API token. Remember to keep it safe.
Supermetrics supports 2 Adtraction query types:
- Advertiser
- Affiliate accounts
If you're logged with an API token belonging to an advertiser account, you can only use the report types intended for advertiser users. The same applies to affiliate accounts.
For Excel users
- Under Data source, select Adtraction.
- Enter your account name and API key.
- Navigate to "Report configuration".
- Select your query type and approval status.
- Navigate to Adtraction and click Try.
- Click Authorize.
- If you're connecting Adtraction for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
