Use the Snapchat Marketing data source connector to pull your basic ad metrics from Snapchat and move the data to your destination of choice. Get detailed data on how much time viewers are spending with your ads and what the click and conversion ratio is.
For a full list of metrics and dimensions available in our Snapchat Marketing data source connector, take a look at our Snapchat Marketing documentation.
Once you’ve connected to Snapchat Marketing, you're ready to create your first queries!
Try these queries
See cost per date
Take a look at how your cost has evolved over time.
The "Cost" metric shows the amount spent on an ad.
- Set the date range to Year to date.
- Select the Cost metric.
See cost per campaign
Check how much your campaigns have cost during the last 28 days.
- Select the Campaign name dimension to split the query results by campaign.
See the value of conversion purchases compared to impressions and cost
See how your ad spend is reflected in the conversions and conversion purchases. In this example, we take a look at the purchases, purchases value, impressions, and cost for the last week.
The "Purchases" metric shows the amount of purchases. The "Purchases value" metric shows the total value of purchases. The "Impressions" metric shows the amount of impressions for an ad.
For best results in Looker Studio, use the bar chart type.
- Select the Purchases, Purchases value, Impressions, and Cost metrics.
See cost, impressions, paid impressions, and swipes per ad squad
Take a look at how your ad squads are doing this month. In this example, we examine the cost, impressions (both organic and paid), and swipes for each ad squad.
The "Impressions" metric shows the amount of impressions for an ad. The "Paid impressions" metric shows the amount of paid impressions for the ad. The "Swipes" metric shows the swipe up count.
- Set the date range to This month to date.
- Select the Cost, Impressions, Paid impressions, and Swipes metrics.
- Select the Ad squad name dimension to split the query results by ad squad.
The Snapchat Marketing data source includes the following limitations:
- Hourly breakdown is supported only for main advertising metrics, but not for conversion data.
- Breakdown by demographic insights and by time is only available from January 1, 2020, onwards.
- If you want to fetch demographic data for a time period before January 1, 2020, we’ve added lifetime versions of demographic dimensions, which ignore the date selection and return lifetime value for the selected metric.
- Reach (unique impressions) and frequency metrics are supported only on daily granularity and by campaign. Weekly and monthly granularity isn't supported.
See the Supermetrics blog for how to create an in-depth report for Snapchat Marketing.
