Follow these steps to connect your Prisjakt data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, and Excel. You can also connect to data sources from the Supermetrics Hub.
Before using the Prisjakt connector, you need a client ID and client secret. To get your client ID and client secret, reach out to your Prisjakt contact person. There is no self-service option at the moment.
Please note that each client ID and client secret has access to specific shops in Prisjakt. Make sure that your client ID and client secret have permissions to all relevant shops you want to use in Supermetrics.
- Product performance: Pull a month-level report of the dimensions and metrics.
- Under Data source, select Prisjakt.
- Enter the client ID and client secret.
- Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple logins.
- Navigate to Prisjakt and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Prisjakt requires authorization to connect to data").
- Hover over the Prisjakt data source, and click Connect.
