YouTube Public Data connection guide
Follow these steps to connect your YouTube Public Data data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to YouTube Public Data, you need a Google account.
  • Channel: Retrieve channel details and performance data for any YouTube channel.
  • Channel videos: Retrieve YouTube video details and performance data for all videos of any YouTube channel.
  • Video: Retrieve YouTube video details and performance data for any YouTube video.
  3. Click Create new query.
  4. Under Data source, select YouTube Public Data.
  6. Click Start.
  7. Select the Google account you want to login with.
  8. Select your account or brand account.
  9. Click Continue.
  10. Click Allow to allow the Supermetrics app to access your profile data.
  11. Navigate to Report configuration and select a query type.
  2. Navigate to YouTube Public Data and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "YouTube Public Data requires authorization to connect to data").
  5. Select a Supermetrics team that has access to the account you want to connect.
  7. Click Start.
  8. Select the Google account you want to login with.
  9. Select your account or brand account.
  10. Click Continue.
  11. Click Allow to allow the Supermetrics app to access your profile data.
  12. Click Complete and continue, and click Close this window to return to Looker Studio.
  13. Select your Supermetrics team and a query type, and click Next.
  14. Insert the channel or video ID.
  15. In the pane's top right, click Connect.
  16. Click Create report.
  17. Click Create report again.
Excel
  1. Open an Excel file.
  3. Under Data source, select YouTube Public Data.
  5. Click Start.
  6. Select the Google account you want to login with.
  7. Select your account or brand account.
  8. Click Continue.
  9. Click Allow to allow the Supermetrics app to access your profile data.
  10. Navigate to Report configuration and select a query type.
Data warehouse
  3. Click + Create transfer.
  4. Select the YouTube Public Data data source.
  7. Accept the agreement.
  8. Click Authorize with YouTube Public Data.
  9. Click Start.
  10. Select the Google account you want to login with.
  11. Select your account or brand account.
  12. Click Continue.
  13. Click Allow to allow the Supermetrics app to access your profile data.
  14. Select the accounts you'd like to include in your reporting and define the transfer settings.
  15. Click Submit.
  16. Click Save.
  2. In the sidebar, go to StorageTransfers.
  3. Click New transfer. If you haven't created any transfers yet, click Schedule first transfer.
  4. Select the YouTube Public Data data source, and click OK.
  7. Click Start.
  10. Click Continue.
  12. In the transfer setup view, select the accounts you'd like to include in your reporting.
  13. Click Create transfer.
Power BI
  2. In the sidebar, go to DestinationsPower BI.
  3. Click Create or edit queries.
  4. Click Select data source.
  5. Select the YouTube Public Data data source.
  6. Click Start.
  9. Click Continue.
  11. Fill in the query details.
  12. Click Run query to test your query.
The Supermetrics API
  2. In the sidebar, click API.
  6. Click Start.
  9. Click Continue.
  11. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  12. Click Run to test your query.
Supermetrics Hub
  2. In the sidebar, click Data sources.
  4. Hover over the YouTube Public Data data source, and click Connect.
  5. Click Start.
  8. Click Continue.
