Learn how to connect your RTB House data to Supermetrics.
Your RTB House account must have API access enabled in order for you to connect it to Supermetrics.
Reach out to your RTB House representative to set this up.
- Performance: Measure the performance of your retargeting campaigns.
- Branding: Measure the performance of your branding campaigns.
- Under "Data source", select RTB House.
- Enter your RTB House username and password.
- Navigate to RTB House and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "RTB House requires authorization to connect to data").
- Click Authorize.
- under "Data source", select RTB House.
