Rakuten Advertising connection guide
Follow these steps to connect your Rakuten Advertising data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and data warehouses, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Supermetrics fetches performance data for affiliate campaign advertisers through Rakuten Advertising. It doesn't currently support the platform's publisher side.
To connect to Rakuten Advertising, you need to create a report, and then get your report key and API token. Follow the steps below to meet these prerequisites.
1. Create a report in Rakuten Advertising
  1. Log in to Rakuten Advertising.
  2. Navigate to Reports, and then Reporting.
  3. Select an existing report, or build a new one. Select every column that you want to use in Supermetrics. You can alter the time range and other report settings at any time in Supermetrics itself.
  4. Save the report.
2. Get your report key and API token
  1. Open the report you want to use in Supermetrics.
  2. Click the dropdown next to View report.
  3. Click Get API.
  4. You'll see your API URL. From it, pull:
    • Report key: Copy the string that follows /reports/ in the URL. It should match the name you gave your report.
    • API token: Copy the string that follows &token= in the URL.
    • Here's an example: //ran-reporting.rakutenmarketing.com/en/reports/[REPORT-KEY]/filters?date_range=this-month&include_summary=Y&tz=GMT&date_type=transaction&token=[API-TOKEN]
  5. Save your report key and API token securely.
  3. Click Create query.
  4. Under Data source, select Rakuten Advertising.
  5. Enter your report key and API token.
  6. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  2. Navigate to Rakuten Advertising and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Rakuten Advertising requires authorization to connect to data").
  6. Enter your report key and API token.
  7. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Choose to make this connection shared or private.
  9. Click Start.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Rakuten Advertising.
  4. Enter your report key and API token.
  5. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
Data warehouse
  3. Click + Create transfer.
  4. Select the Rakuten Advertising data source.
  7. Accept the agreement.
  8. Click Authorize with Rakuten Advertising.
  9. Enter your report key and API token.
  10. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  11. Select the accounts you'd like to include in your reporting and define the transfer settings.
  12. Click Submit.
  13. Click Save.
  2. In the left-side menu, under Export, go to Data warehousing → Transfers.
  3. Click Create new.
  4. Select the Rakuten Advertising data source, and click OK.
  7. Enter your report key and API token.
  8. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  9. Click Start.
  11. Click Create transfer.
The Supermetrics API
  4. Click Select data source.
  5. Select the Rakuten Advertising data source.
  8. Click Start.
Supermetrics Hub
  4. Hover over the Rakuten Advertising data source, and click Connect.
  7. Click Start.
