Supermetrics Dashboards provide quick and easy access to essential marketing insights, allowing you to visualize and understand data from multiple marketing sources without the hassle of complex reporting or technical setup.
Note
The Supermetrics Dashboards is a beta feature and we're improving this feature for the future. Let us know what you think about the dashboards and what you'd like to see on them!
Key features:
- Out-of-the-box dashboards: Access pre-built dashboards that provide key insights without the need to configure or create reports from scratch.
- Popular data sources and use cases: Includes integrations with the most commonly used marketing data sources, such as paid media and web analytics.
- Single source of truth for the team: Dashboards are shared across the team so that the whole team sees the same data and can use the data for decision-making.
In the first release, we have 3 dashboards available:
- Paid media performance — includes the following data sources:
- Microsoft Advertising (Bing)
- Google Ads
- Facebook Ads
- LinkedIn Ads
- X Ads (Twitter)
- TikTok Ads
- Facebook Insights overview
- Google Analytics 4 overview
To modify the dashboards, you need Owner, Admin, or Editor access. Users with Viewer or Finance roles can't modify dashboards.
Set up your dashboards
- On the Supermetrics Hub, select Dashboards from the left navigation.
- Select a dashboard template and click Open.
- On the dashboard page, click Data sources and accounts.
- For the data sources you already have a connection for, select the connection and account to use. You can also create a new connection to the data source. Note that as Dashboards are shared with the team, you can only use shared connections in Dashboards.
- For the data sources you haven't connected to, click Connect to log in and select the account to use.
- Note that you can only add one account per data source at this point.
- The dashboard will populate with your data.
You can adjust the data on the dashboard using the dropdowns, such as metrics used and date range. Note that as the dashboards are shared with the team, making changes in the dashboard changes the data for the whole team.
