Teads connection guide
Follow these steps to connect your Teads data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Teads account, you need to create an API key.
Create an API key
  1. Log in to your Teads account.
  2. Click the gear icon in the header to open the Settings screen.
  3. Click Generate API key in the API Keys section.
  4. Click the edit icon to change the API Key name.
  5. Copy the API key shown under the name of the key. You need the key when connecting Teads to Supermetrics.
  3. Click Create new query.
  4. Under Data source, select Teads.
  5. Enter your API key, and give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
Excel
  1. Open an Excel file.
  3. Under Data source, select Teads.
  4. Enter your API key, and give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  6. Click Start.
Data warehouse
  3. Click + Create transfer.
  4. Select the Teads data source.
  7. Accept the agreement.
  8. Click Authorize with Teads.
  9. Enter your API key, and give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  10. Click Start.
  11. Select the accounts you'd like to include in your reporting and define the transfer settings.
  12. Click Submit.
  13. Click Save.
  3. Click Create new.
  4. Select the Teads data source, and click OK.
  7. Enter your API key, and give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  8. Click Start.
  9. In the transfer setup view, select the accounts you'd like to include in your reporting.
  10. Click Create transfer.
Power BI
  3. Click Select data source.
  6. Click Start.
  7. Fill in the query details.
  8. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the Teads data source.
  6. Enter your API key, and give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  7. Click Start.
  8. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  9. Click Run to test your query.
Supermetrics Hub
  4. Hover over the Teads data source, and click Connect.
  6. Click Start.
