Availability
The Reddit Ads connector is currently in closed beta. Get in touch with our support team if you have any questions.
Use this guide to connect Reddit Ads to Supermetrics.
For Excel users
- Click Create query.
- Under Data source, select Reddit Ads.
- Enter your account details, and click Sign in.
- Click Allow.
- Select your query type and target URL.
- Navigate to Reddit Ads and click Try.
- Click Authorize.
- If you're connecting Reddit Ads for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Click Allow.
- Click Allow.
