This guide contains all permissions and requirements for connecting your WooCommerce data to Supermetrics.
To connect Supermetrics to your WooCommerce store, you’ll need a consumer key, consumer secret, and store URL.
These keys can be obtained from WooCommerce. Go to WooCommerce → Settings → Advanced → REST API. WooCommerce's documentation has detailed steps to get the keys.
Note that prior to WooCommerce version 3.4, the key generation was located at WooCommerce → Settings → API → Key/Apps.
- Sales overview: Report the overall sales for the store.
- Orders: Fetch details of orders for your store in a certain time range.
When connecting to WooCommerce, you need to enter your consumer key, consumer secret, and store URL and select a store and query type when prompted.
- Select the WooCommerce data source on the Supermetrics Hub or in the data destination.
- Insert your consumer key, consumer secret, and store URL.
- In your data destination, select a store to fetch data for and query type to use.
You can also connect to WooCommerce from these destinations:
More information
- How to reauthenticate a data source in Google Sheets, Looker Studio, Excel, or Power BI
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
