DoubleVerify connection guide
Follow these steps to connect your DoubleVerify data to Supermetrics.
To connect Supermetrics to your DoubleVerify account, you need to create an access token.
Create access token
  1. Log in to the DoubleVerify platform.
  2. In the top navigation bar, hover the cursor over Analytics and click Data API.
  3. Click Create new token.
  4. Select the Reporting Programs you want to fetch data from.
  5. Click Create.
  6. Copy the Access Token Hash and store it in a secure place for later use.
  • Standard: Measure the authenticity of your ads using DoubleVerify authentic ad metrics.
Google Sheets Looker StudioExcel
  3. Click Create new query.
  4. Under Data source, select DoubleVerify.
  5. Enter your Access token.
  6. Enter a name for your account for you to identify it later.
  7. Click Start.
