Follow these steps to connect your Basis data to Supermetrics and use your data in Google Sheets, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Basis account, you’ll need your Basis username and password.
- Campaign performance: Get campaign performance data.
- Under Data source, select Basis.
- Log in with the account you use to log in to Basis.
- Click Log in.
- Click Agree.
- Select the accounts you’d like to include in your reporting.
- Click Log in.
- Click Agree.
- Click Select data source.
- Select the Basis data source.
- Click Log in.
- Click Agree.
- Fill in the query details.
- Click Log in.
- Click Agree.
- Hover over the Basis data source, and click Connect.
- Click Log in.
- Click Agree.
