Using the Supermetrics Query Manager, you can easily create queries and connect your data from various data sources to Qlik Sense via the Supermetrics API.
We recommend using the KEY-JSON output format.
See Qlik documentation for more information about creating a REST connection to transfer your data.
- On the Supermetrics API, go to API queries under Manage.
- Click Select data source.
- Select a data source and connection to use.
- In the sidebar on the left, build your query. Click Run to test it and review your data in the preview.
- From the URL format options, select K-JSON.
- Copy the K-JSON URL.
- Open Qlik Sense, and create a new app.
- Continue to add data to the app.
- In the Add data view, select the REST option.
In the connection configuration view, paste the Query URL you copied from the Query Manager in step 7 into the URL field and select a name for the connection.
Click Test connection to ensure the configuration is valid.
To finalize the setup, click Create.
