Use this guide to connect Pinterest Public Data to Supermetrics.
Pinterest Public Data allows you to collect publicly available data about Pinterest posts. It doesn't require you to log in to a specific account.
- Pinterest pins for URLs: A count of how many times a specific URL has been pinned
- Pinterest user data: User information like account name, profile link, follower count, and more
- Pinterest pins for users: Data on user pins, including Pin URL, image, description, and more
- Click Create query.
- Under Data source, select Pinterest Public Data.
- Select your query type, and then add your Pinterest username under Type URLs. You can add more than one username, each on a new line.
- Navigate to Pinterest Public Data and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Pinterest Public Data requires authorization to connect to data").
