How to check the Power BI version in use
The Supermetrics connector for Power BI has been certified by Microsoft and comes with Power BI Desktop starting from version 2.128.751.0 (April 2024 update).
Follow these instructions to check which version on Power BI Desktop you're using.
  1. Launch Power BI Desktop.
  2. Open the Help tab on the top menu.
  3. Click About to check the version that you're currently using. To use the certified Supermetrics connector, the version needs to be at least 2.128.751.0 (April 2024 update).
If you have an outdated version of Power BI Desktop, download the latest version from the Microsoft Download Center. Windows 10 users can also download the latest version of Power BI Desktop from the Microsoft Store.
