Learn how to connect your Apple Search Ads data to Supermetrics.
Your account needs the API Account Manager or API account read-only user role to connect. Learn more about user roles in Apple's documentation.
There are two ways to connect Supermetrics to Apple Search Ads.
- For most users, we recommend using OAuth. This allows you to log in with your Apple ID in a few quick steps.
- If you need to connect multiple user accounts to access different collections of ads, we recommend the API username and secret key setup.
If you're connecting with an API username and secret key, follow the steps below to get the credentials you need to connect.
Get an API username and secret key
- Open Supermetrics in your report. Click Data source, and then Apple Search Ads. If you're using Data Studio, click Authorize when prompted.
- A dialog should open. Scroll down and click Click here to download your public key certificate.
- Once your download's complete, find the file in your "Downloads" folder (it'll be a .pem file).
- Right-click on the .pem file. Click Open with, and select a text editor (like Notepad on Windows, or TextEdit on Mac). Leave the file open while you follow the steps below.
- Log in to Apple Search Ads with your API user account.
- Click on your username on the top right, and navigate to Settings.
- Copy the whole text from the public key certificate file you downloaded earlier and paste it into the Public key field. The file should include both BEGIN PUBLIC KEY and END PUBLIC KEY.
- Click Generate API client.
- This will generate the Client ID, Team ID, and Key ID. Click Save to save those credentials.
- Return to the Supermetrics login dialog.
- Copy the Client ID, Team ID, and Key ID, and paste them into the fields with those labels.
For Excel users
Connect with OAuth
- Click Create query.
- Under Data source, select Apple Search Ads.
- Click Connect with OAuth.
- Log in with the Apple ID you want to use to pull data.
- Grant "Account Read-Only" access, and click Grant Access.
Connect with an API username and secret key
- Click Connect with API username and secret key.
- Enter your Client ID, Team ID, and Key ID from "Step 2: Generate API client".
Connect with OAuth
- Navigate to Apple Search Ads and click Try.
- Click Authorize.
- If you're connecting Apple Search Ads for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Click Authorize.
- Click Authorize.
Connect with OAuth
