How to use data blending in your data destination
Follow these instructions to use data blends in Google Sheets, Looker Studio, Excel, Power BI, data warehouse destinations, and Query Manager (the Supermetrics API).
Learn more about how the data blending feature works.
If you're interested in the data blending feature, contact us.
You need to create your data blends on the Supermetrics Hub before they can be used in destinations.
  1. Navigate to Extensions → Supermetrics → Launch sidebar to open the Supermetrics sidebar.
  2. Click Create new query.
  3. Under Data source, select Data Blending.
  4. Select a connection.
  5. Under Available blends, select a data blend.
  6. Select metrics and dimensions.
  7. Click Get data.
Note
When using data blending in Looker Studio, you need to first connect to Data blending to Looker Studio from the Supermetrics Hub. Otherwise, the Data blending data source doesn’t show up in Looker Studio.
After connecting, you can find the Data blending data source on Looker Studio.
Follow these steps to connect Data blending to Looker Studio:
  1. On the Supermetrics Hub, go to Data blending under Manage.
  2. Click Use your blends in destinations.
  3. In the popup, click Go to connector to connect the Data blending data source to Looker Studio.
  4. In Looker Studio, select a Supermetrics team and click Next
  5. Select a data blend, and click Connect.
  6. Click Create report, and then Add to report.
  7. Select metrics and dimensions.
After connecting Data blending to Looker Studio, you can find the Data blending data source the same way as other data sources:
  1. In Looker Studio, click Add data.
  2. Select the Data Blending data source by Supermetrics.
  3. Select a team, and click Next.
  4. Select a data blend.
  5. In the pane's top right, click Connect.
  6. Click Create report.
  7. Click Add to report.
  8. Select metrics and dimensions.
Excel
  1. Click Data → Show Supermetrics to open the sidebar.
  2. Under Data source, select Data blending.
  3. Select a connection.
  4. Under Available blends, select a data blend.
  5. Select metrics and dimensions.
  6. Click Get data.
Power BI
In Power BI, the Data Blending data source is available through the old Query Manager.
  1. On the Supermetrics Hub, go to Power BI under Analyze.
  2. Click Manage queries in the old query manager.
  3. Select Data Blending as the data source.
  7. Click Run query.
  8. To make the query available for Power BI, click Save query.
Query Manager (API)
  1. On the Supermetrics Hub, go to API queries under Manage.
  2. Select Data Blending as the data source.
  6. Click Run.
Data warehouse and data lake
