Follow these steps to connect your ActiveCampaign data to Supermetrics.
Before using the ActiveCampaign connector, you need a copy of your API URL and API key and appropriate permissions for data access on your account.
Depending on your needs, your account needs access to the following objects in ActiveCampaign:
- Campaigns
- Deals
- Accounts
- Contacts
Each user in ActiveCampaign has their own API URL and API key. To get these:
- Log into ActiveCampaign with your account.
- Navigate to Settings → Developer.
- Copy the URL and key from the API Access section.
- Campaigns report: Follow the performance of your email campaigns.
- Deals report: Track the status of your sales deals.
- Accounts report: Fetch details of your customer accounts.
- Contacts report: Fetch details about your contacts.
For Excel users
- Navigate to Extensions → Supermetrics → Launch sidebar to open the Supermetrics sidebar.
- Under Data source, select ActiveCampaign.
- Enter a name for your account for you to identify it later.
- Enter the API URL and API key.
- Select your accounts.
- Navigate to ActiveCampaign and click Try.
- Click Authorize.
- Click Authorize.
- Choose if this connection should be shared or private.
