Follow these steps to connect your Google Merchant Center data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, and Excel, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Google Merchant Center account, you need a Google Merchant Center ID. The ID can be found in the top right corner of your Google Merchant Center account.
- Performance: Retrieve merchant performance metrics matching the search query and optionally segmented by selected dimensions.
- Product: Offers an overview of all your products.
- Diagnostics: Offers issue reporting across your account and items grouped by the context in which your product data might show.
- Under Data source, select Google Merchant Center.
- Enter the ID of your Google Merchant Center account.
- Select the Google account associated with your Google Merchant Center account where you want to fetch data from.
- Click Allow to allow the Supermetrics app to access your profile data.
- In the Supermetrics sidebar, navigate to Report configuration, and select a query type.
- Navigate to Google Merchant Center and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Google Merchant Center requires authorization to connect to data").
- Select a query type to use in your reporting, and click Next.
- Click Select data source.
- Select the Google Merchant Center data source.
- Hover over the Google Merchant Center data source, and click Connect.
