Follow these steps to connect your Instagram Public Data data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Instagram Public Data to Supermetrics, you need a Facebook user account linked to an Instagram account with the Manage Page role. Learn more in Instagram's documentation.
Your Instagram account must be:
- An Instagram Business account (sometimes called a "professional account"), or a Creator account that uses Facebook authentication and isn't restricted, age-limited, or private.
- Linked to an active Facebook Page which has been claimed.
Visit Instagram's help center to learn how to change your account type.
Your Facebook account must:
- Be a Facebook user account with View Page performance and Create ads permissions. Admin access — Manage page isn't required, but will work.
- If it's using the new Pages experience, the account needs Full control access to the Facebook Page linked to the Instagram account.
Story, Reel, and IGTV data aren't available for Instagram Public Data. See the list of available data fields in our technical documentation.
When you connect Instagram Public Data, you'll use a query type to define your data. Browse these below.
- Returns the current amount of followers, follows, and posts for the account user search for.
- Returns basic account info: name, username, Instagram ID, bio, profile pic URL, website link.
Recommended uses
Keep track of an account's follower count, or its posting frequency, using the Supermetrics “Combine new results” feature.
Limitations
- Private, restricted, or age-limited data can't be fetched.
- "Error: Invalid profile name" can mean that the account name is invalid or that the account is restricted, age-limited, or private. Historical data of account followers or post amounts can't be fetched. However, you can use the “Append results” and scheduled refresh features to gather data over time.
- Returns posts of pages that are publicly available.
- Post types include image, video, and carousel.
- Can fetch data from the past and from a selected time period. Can also be used to get data on posts that are otherwise geo-restricted.
- Shows basic post metrics (likes, comments), post URL, image URL (first image for carousel), post type, caption, and more, together with profile information.
Recommended uses:
- Follow new posts from multiple accounts, that are difficult to manage.
- Find and analyze top-performing posts from other accounts, like. which content types, hashtags, and captions are performing well.
Allows you to search for posts tagged with a specific hashtag.
The hashtag can be either in the post caption or as a comment. Hashtags can be added only by the original poster.
Post search has two query types: Top and Recent.
- Top returns a list of 100 top posts based on Instagram's algorithm rather than on likes or comments.
- Recent returns a list of posts made within the last 24 hours with the specified hashtag.
Recommended uses:
- Follow discussions happening with specific hashtags.
- Follow and store new posts with specific hashtags.
- Find other hashtags used together in popular posts.
- Find which profiles are popular and are discussing using specific hashtags.
- Under Data source, select Instagram Public Data.
- Log in with a new Facebook account, or click Reconnect to log in with the account you're currently logged in to.
- Navigate to Report configuration and select a query type and Instagram profiles to use in your report.
- Navigate to Instagram Public Data and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Instagram Public Data requires authorization to connect to data").
- Select a query type and click Next.
- Select the Instagram profiles to include in your report.
- Click + Create transfer.
- Select the Instagram Public Data data source.
- Accept the agreement.
- Click Authorize with Instagram Public Data.
- Select the profiles you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Instagram Public Data data source, and click OK.
- In the transfer setup view, select the profiles you'd like to include in your reporting.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Instagram Public Data data source, and click Connect.
