Follow these steps to connect your Quora Ads data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
You need a Quora account with the Admin user role to connect to Supermetrics. Learn more about granting access to account in Quora's documentation.
- Under Data source, select Quora Ads.
- Enter your email address and password, and click Log in.
- Click Accept.
- Navigate to Quora Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Quora Ads requires authorization to connect to data").
- Enter your Quora Ads email address and password, and click Log in.
- Click Accept.
- Click Accept.
- Click + Create transfer.
- Select the Quora Ads data source.
- Accept the agreement.
- Click Authorize with Quora Ads.
- Click Accept.
- Click Submit.
- Click Save.
- Select the Quora Ads data source, and click OK.
- Click Accept.
- Click Create transfer.
- Click Select a data source.
- Click Accept.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Click Accept.
- Hover over the Quora Ads data source, and click Connect.
- Click Accept.
