This guide will walk you through how to authenticate Apple Public Data with Google Sheets, Looker Studio, and Microsoft Excel.
Please note that this data source is in early access, which means we're still fine-tuning its features. We'd love to hear your feedback.
- Click Create query.
- Under Data source, select Apple Public Data.
- Under Query type, select the query type.
- Insert Keyword(s) or App ID(s) for searching apps. To select different apps, separate each one with commas.
- Select App Store country.
- Select the Platform (such as iPhone or Mac) and Maximum results per search term.
- Open this Looker Studio link.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Apple Public Data requires authorization to connect to data").
- Under Query type, select the query type and click Next.
- Insert Keyword(s) or App ID(s) for searching apps. To select different apps, separate each one with a comma.
Before you can authenticate this data source in Excel, you need to install the Supermetrics add-in.
When you're ready, learn how to create your first Supermetrics query with Apple Public Data.
